FactoryTalk View SE VBA user form
rifem
Oct 2007
IOWA
My issue:
We run FactoryTalk View SE (6.1 currently) at our plant. (First issue, right..lol)
Our data historian is Wonderware Historian 10.1.
We have an ongoing issue with latency when we first access our Wonderware Historian Trend Client activex. There is VBA behind a button click on a display. Using a userform with the activex installed. Our VBA code populates all the pertinent properties.
After the first delayed access, all subsequent attempts run fine.
There are no issues with the connection to the Insql Historian server at all. We can run Historian Trend on the client and it will run fast with no issues. Historian pings fine, 25ms round trip. The VBA code used does not seem to affect the performance, I have deleted all the code and notice just having the form with the activex causes a delay.
I am 99 percent sure it is an issue with how FTV SE handles the activex.
Any help would be greatly appreciated.
Any chance you could put a simple do nothing call to the ocx in your startup folder? This would load the ocx and get it ready for you.
I'm creating an HMI that has a recipe with 288 data point. It has 3 pieces of data for 96 segments. I need help with VBA code to copy all 288...
141
Hi, Can someone guide me through how to use FactoryTalk SE VB script to open communication with SQL Server? which command I can use? Are there...
2,303
Hello group, I have been migrating a project from RSView 32 V7.6 to FactoryTalk View SE Local Station V12 over the last couple of days. All told...
998
For trend charts, I can use an ActiveX Calendar control to select a date on a trend using the following code where "Trend" is the name of the...
1,582
Anyone know how to change the mouse icon to something else using VBA? It looks like it can be done with VBA forms and based on the object the...
2,218
