FactoryTalkView Studio 6.10 ME Faceplate Error
pr_wainwright
Jun 2011
Stockton on Tees
109
I am trying to use the Logix Processor Faceplate in a FactoryTalkView ME application but I get the following runtime errors & do not know how to resolve.
Error 1: [FactoryTalk]: The item is no longer available: #2@SetPropertyCalls
Error 2: [FactoryTalk]: The item is no longer available: #1..Cmd_ClearFaultRecord
Any help appreciated.
Paul.
Usually these faceplates have directions that instruct you how to use parameters with the faceplate. They won't be usable until you do.
Take a moment and read up on that.
OG
Operaghost is absolutely right. Process faceplates are per-configured graphic displays. The display is trying to find a Tag, which either you forgot create or link or you doesn't need it but it exist on some object on your display screen.
Delete it, if you dont want it or direct it to a tag on PLC.
InstrumentationUK,
I contacted a Rockwell & got told to delete the 2 offending items, but I dont know where to delete them. In RsLogix 5000 or FactoryTalkView ME?
Paul.
InstrumentationUK,
I would if I could find where to delete them from. I assume that @SetPropertyCalls is some sort of parameter but I can't find a reference to it anywhere.
Paul.
This question may be odd but I am a maintenance guy and just started with Rockwell automation software. I have got a computer from my new current...
10,321
Hello Community, I have this problem that i need 2 sets of the same global object (LBSM) and faceplate display for LBSM. How is it possible to...
1,185
Hi all, Is there any chances i can get any demo software to open the program of Panelview plus 700 HMI? I tried but couldnt get any...
1,495
Hello there. I have a project to convert from RSVIEW32 to FTVS, Machine Edition. Working on Graphic objects. Does anybody know the equivalent...
1,952
Hi, I have a FactoryTalkView ME application running on my HMI & I am testing how the Alarm banner works. I have a bool that I have set to...
2,761
