I have a timer array and need to 'copy' the .acc's to another array. This is part of data analysis being requested so there is a lot of copy and paste hence the use of array's.
I've tried to FAL's and they only 'move' the first value in each case. I've had a look at the FAL flow chart and it should repeat for each loop control. Any help or advice would be appreciated.
The second FAL of the image attached is an attempt at dividing the .acc to get seconds.
I'm using a L72, v32
