Fanuc Analog Input
12gage
Nov 2011
Bentley, MI
I am having a hard time retrieving data from a analog input module(AA04DA). We have a Fanuc CNC application. I am seeing a difference in voltage from 0 to 11 volts from the switch, but do not see anything change in the PLC. I have the card configured to the appropriate slot and group. Designated to inputs x0.0 - x0.7. Shouldn't I be able to see the inputs change state? Is there a specific register I need to look at for the values. Thanks for any replys. Is there anyways to test the card to make sure it is functioning properly?
Verify that it is wired correctly, it is very easy to get a wire 'off' by one terminal on these.
The Fanuc CNC has a PMC not a PLC how are you monitoring this? Yes there is a specific parameter or address that each channel should be updating. Consult your controlls documentation for this.You indicate it is x0.0 - x0.7, but IIRC those are discrete locations.
Don't know of a way of testing them without a controller and programmer.
Hello all, Thanks for the forum which has provided me with a lot of help overtime. I'm posting my first thread since I can't seem to find an...
2,052
I'm trying to configure a 16 input analog input card (IC693ALG223) to work with a CPU 331. When I try to store the configuration to the PLC, I...
4,667
Hi Guys, I was given a task to configure using level setpoint to have an output of 4-20ma equivalent using GE Fanuc 9070. Is this possible? If...
2,055
Hi, I have a small LCP8 Linear Potentiometer I use to send analog values to my 90/30 GE Fanuc. I know that an analog value of 0.01426671 equals...
3,265
Hi, Its Hamid Ali from PAKISTAN. i have expertise in YOKOGAWA DCS (CENTUM CS3000 & CENTUM VP). but from now i want to learn GE FANUC PLC. I...
2,172
