Fanuc Drive e-Stop torque limit
NevisGroup
Jan 2014
Wisconsin
78
Hello all:
I have a Fanuc AISV (A06B-6124-H102) drive being controlled by a GE PMM335 PAC Motion controller.
I need to limit the amount of torque that is applied when an E-Stop is activated mid motion. The drive applies max stopping power to the motor and it is causing mechanical problems.
(It is breaking things)
I could live with the drive just letting go of the motor and letting it coast to a stop. (There are hard stops that will take the brunt of the crash with out a problem).
PS. There is no saftey issue with allowing the motor to coast
Thanks for you input Steve. But no luck...
I am already dropping the contactor on E-stop.
It looks like the output of the drive is hard d-braking the motor, which is fairly common.
But there is usually a way to disable or at least limit that function for high inertia loads. I just can't find it here.
(BTW GE / Fanuc have gone out of their way to make getting info difficult.)
How about if you only drop the contactor on E-Stop and don't open the E-Stop connection on the amp?
Also, consider the possibility that you have too much motor for the drivetrain. If you can damage components by stopping too fast you could potentially damage them by accelerating too fast.
I did finally get word back from Fanuc. When the drive E-Stop opens the AMP shunts the motor. This can not be turned off.
I ended up with a delayed safety to issue a stop to the drives before killing power. This will cover 99% of the E-Stop situations. Something like a power fail will not be covered. The best I can do is warn the customer about it.
The motor / drive combination is sized correctly for the normal operation of the machine. The max motor torque during normal operation is well within the mechanical limits. The problem is an uncontrolled stop. With a large enough load, you could potentially reach de-mag currents with an uncontrolled stop.
On to different issues with this system....
Hi All , I have a Fanuc Robot System(R-30iA) with a drive ( FANUC A05B-2500-C001 ) , and I need to Know how to upload \ Download a backup from\...
3,251
Dear all, I have a three axis CNC turning machine ,last day i face a problem in Power supply module and servo axis module.In the PSM...
4,625
please someone help me dear on fanuc plc and drive , actually i have a cnc machine and i doesnt kknow any thing abt its programming but i know...
1,806
do all of u experts know that Fanuc servo drives are designed as if u the cooling fan stops for any reason ,the drive woud stop and tells u that...
2,299
I have a project with a Altivar 71 drive and need to read and write parameters within the drive. I will need to change the Hz and voltage...
2,165
