FANUC Ladder III-PID Loop control
Swingmanstan
Nov 2020
Blue Springs
Old Allen Bradley guy here: I used to have a SCL or SCP and then a PID tuner block to use.
Here in the FANUC ladder world I have not been able to use a function block that does PID loop. I was told I had to buy a different PMC package to get SUB 460.
I would like to hear any suggestions for a simplified PID, controlling a 0-10 V modulating valve from 1 4-20mA pressure input.
Stan
Not sure I understand your question. Are you asking how some type of proportional control can be accomplished, without using a built in PID function?
If so, then:
Details? What are we controlling, how fast does the system respond in manual control? What amount of error (if any) can you tolerate?
instrument & controls engineer
Thank you for responding. I have found out that there is a PID function block available. SUB 460 is available on some models in the extended function list. I'm still a beginner with FANUC and finding things is not the easiest.
Been there (trying to find info in an unfamiliar environment)!
If that block does not work out, note that the PID formula is straightforward and can be coded (ladder, fb, st, etc.) and tested in an afternoon, including bells and whistles: it's almost all bookkeeping.
KenM's post #2 in this thread is worth considering: something simpler than PID is sometimes adequate, or even better than PID, depending on the process.
Hi... I cant able to view 0i-F series logic in Fladder III 5.80 version. Should i need to update or anything else?
1,095
Hey can anyone help me. I'm working with Fanuc Ladder III and I have 2 questions. 1) Under relay comment you are only allowed 16 characters I...
3,402
Where can I get info on Fanuc Ladder data types? example: F0126.3 I can program Allen-Bradley and Automationdirect PLC's even some SquareD stuff...
12,779
Hello Everyone, I would like to get some advice from seniors!! Currently, I involve in writing PLC logic and Robot programs (ABB rapid...
3,895
Can anybody here explain how do we know the number on address at fanuc ladder diagram? ex : Y0003.0 , F0000.6 , X0008.4 , R0552.0 , etc i don't...
3,541
