ceilingwalker
Hello all. I have a Fanuc 18i control and I'm not familiar with there ladder logic at all. Could someone please explain the timer instruction's that Fanuc uses? For example, I'm working on a way-lube fault. The timer on the ladder shows "TMRB 31 1500"
SUB24
My assumption is that it is telling the lube pump to turn on every 31 minutes and run for 1500 mS. Also, does anyone know how to force an output so I can test the pump motor to be sure it isn't faulty. Thanks much for the help.
SUB24
