Roland.Jollivet
Hi All
My first post here. During my searches on the net, the most knowledgeable answers were to be found here;-)
So, while this is not exactly a PLC question, is anyone familiar with the Fanuc R-J3iC controller.
I've been building up an interface box for a R-J3iC controller using a R-J3iB manual as my reference, only to find that the I/O does not work as expected. The inputs, like Enable, Continue, Run, are read when the panel buttons are pressed, but I can't seem to toggle the outputs from the pendant. Also, the R-J3iB ports are labelled CRM2A, CRM2B, but the I/O card on the R-J3iC is labelled CRM5A, CRM5B. I thought this would not matter, as the controller maps it as Rack 0, slot 1 on power up.
So, am I way out in expecting the CRM5A to match the CRM2A connector? And is there some variable I maybe need to set to enable outputs. I can't even toggle the Pause, Perch.. LED's, which are dedicated lines, but so are Perch, Pause, which can be read. My output LED's just stay on. So I made up a simple test cable with one LED, for the Pause line, and was able to toggle it on a R-J3iB panel, but on the R-J3iC panel, it just stays permanently lit.
Other info;
- On the port lines, I tied all the COMx lines to 0V, assuming the outputs are NPN. All my LED's are connected output>LED>+24V. I thought maybe they're PNP, and so tried output>LED>0V, but that did not work either.
- I tried a second I/O card, and it was the same.
- I tried the single LED on a third I/O card, and it was the same. Always permanently on from power up.
Help appreciated.
Regards
Roland
Other info;
Help appreciated.
Regards
Roland
