FANUC to Allen Bradley
Crkondekar
Feb 2019
United States
I am connecting a FANUC L30iA controller with an AB L32E plc on EthernetIP. I am not able to browse the FANUC controller on Linx Classic but I am able to ping it.
Any solutions ??
RSLinx will need an EDS file for the FANUC controller before it will recognize what it is. That doesn't mean you can't make it talk with the L32E but RSLinx won't be able to communicate with it.
There is no universal "out of the box" controller. The installed options vary.
In your case, the Ethernet/IP option is required.
Go to the I/O menu and press F1"Type". If Ethernet/IP is in the list, you got it.
If no, you are out of luck and have to purchase the Ethernet/IP adapter option.
Does anyone know how I can set an Allen Bradley Panelview Plus to read tags from a GE Fanuc 90/70 plc? I can't seem to find anything that will...
5,915
Is it possible to connect a GE Fanuc I/O (via EGD) to an Allen-Bradley's plc? Thanks for any comments!
3,869
hello i need some information about communication ge fanuc 90-30 and controllogix in ethernet ip?? Somebody can help me or send me some...
4,836
3,895
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
39
