FDL communication between CP342-4 and S5 95U with L2 port
oha
Dec 2007
Odense
We have changed a S5-95U/L2 with a S7-314C/CP342-5 and can not get the communication running.Using the standard FC5 an FC6 and can see that the status words is toggling between 8181h/8o81h and 81c5/80c5.In the code evaluation of the Fc's, the error no.stops at 81c4/80c4.
Has anyone seen that before.
From what I recall L2 and L2/DP (Profibus) are not the same
I know that. The S5 and S7 are communicating on FDL basis and I have done that before, but never seen that error message.That's my problem.
Hi all. I have a Modbus ProSoft module in my setup with a capability of 30 clients (0-29), which I'm trying to monitor the Ethernet Connection...
26
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
101
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
41
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
47
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
106
