Festo CPX-FB32
mangletech
May 2008
Doncaster
36
Hi All
having problems using Rockwell BootP to change the IP address of a Festo Valve block
the default IP is 192.168.0.4
DIP switch bank3 all set to off position
I need to change IP to 160.150.140.28
so far tried
Laptop IP set to Auto
Using "New" tab in BootP
entered in the MAC address of the valve block
Entered in the IP of 160.150.140.28
clicked on "Enable BootP"
no success
Tried the same but using a static IP address of 192.168.0.5 and 160.150.140.10 still no success
RS lynx sees the valve bank and I can view its properties when using a static IP of 192.168.0.5
any ideas where I'm going wrong, not a regular user of Rockwwll products
kind regards
Neil Byrne
Festo have a program for this, very easy to use. The last menu is for setting upp the IP adress, and its free to use. I did all this a couple of week ago.If you have troubel to get it running in RSlogix, Festo allso have "export to Rslogix" tool, built in the program.
I think its called festo cpx maintinece tool or something like that. :)
good luck!
I'm trying to get Ethernet/IP communication working to a Festo CPX valve bank using an FB32 from a non-Rockwell PLC (Schneider/Elau PacDrive3). I...
5,592
Hi mentors I have a machine with a contrlogix which it has a festo cpx fb 32 connected to it which works ok , but I was wondering if I could get...
8,249
Hi. We've been asked to do an upgrade on plant, consisting on a PLC upgrade. This involves replacing a 1747-SDN module to a 1769-SDN, in a network...
44
Hi all, First post on here. I'm an automation engineer and I have plenty of experience with Allen Bradley, Siemens and Fanuc etc. Constantly...
2,989
Hello I have an issue with detecting the correct FESTO CPX controller in TIA HW catalog. And I do not know where is the issue, I received the...
1,948
