Fetching an answer to where does fetch fetches from.
jhbishop
Apr 2010
DFW
I know this forum is for PLCs but maybe someone also does iFIX. When a chart configuration window is opened there is a checkbox called Fetch Limit. Does anyone know where it fetches from. I would like to change the limits but my iFIX administrator says he doesn't want them set manually and wants them fetched instead. He thinks the limits are fetched from the PLC but I can't find anyplace in the PLC they can be fetched from. Thank you in advance for your answer.
Hi; In my O/G facility we are using Wonderware Intouch ver 9.5 for SCADA. We need to automate the process of exporting realtime process values for...
2,530
Hi, our company has just switched from older Modicon PLCs to S7 (5x317/2x317F) connected over ProfiNET. We use InTouch 9 for the visualisation...
3,030
A S7-300 PLC is connected to an HMI and live data is being displayed on HMI. I want to fetch this data from HMI into a windows based PC. Is it...
2,450
Hi all, Can anyone tell me what the Com+ 0 and Com- 0 are on the output on the QBB. Bottom one. Thanks
2,153
Hi all, after much aggravation trying to get my SLC5/04 to talk half duplex to RSlogix so l then would be able to communicate with both RSlogix...
2,244
