Ffl-ffu
roxusa
Nov 2008
NJ
994
A couple of questions with RS500 FFL-FFU instruction set.
1-Does the stack load from the bottom or the top, My stack is
#N7:50 with a length of 20, so does the first one go into 50 or 79.
2- Can I change a value in the stack with a move to that location.
I want to set up an HMI to view the stack and possibly make a change
to one of the words if needed. Thanks
Yeah, the FFL will load into N7:50 first and shift them down to N7:69
You can move integers to the direct addresses, always a good practice to document that in the logic so the next guy knows that the values in the stack may be altered from the hmi
The Logix 5000 FIFO (i.e., queue) works backwards. FFL inserts at the end and shifts toward the front (lower address). Is this a change from the RS500 behavior?
as the stack is emptied are the addresses in the stack returned to 0
Your best bet is to drop an FFL and FFU instruction onto a rung, click on it and press F1. The help file is quite detailed and includes some really nice graphics to show exactly how the instructions executes, and how and where the data moves to and from.
I have read the instruction set help for both the FFL & FFU but it doesn't mention which way it loads. I used it years ago on a conveyor system to send an integer with each load so the take off knows which way to discharge the load. I am doing another similar one and wanted to display load directions on the HMI.
I did figure out from reading the Help that the position is the next available open slot in the stack and it looks like since I am using R6:0 as my control register that would be R6:0.POS, I created a rung to subtract 1 from that and store in N7:0 to display the number of loads in stack at my discharge conveyor and will test to see if I'm correct
Thanks All for the input
For those who may recall I had posted previously about the FSC instruction, and while I have a better understanding of how to use it I find myself...
1,381
I have used fifo's before, and I think I understand the general concept. However I am having trouble trying to create one that stores the...
19
11,238
Hey guys, I came across one question about the FIFO, FFL & FFU instruction. I want to measure the wheel speed, so I use the RPM encoder as the...
4,001
When executing a FFU to unload the oldest value the data in the file is shifted down and the position value is changed. Does this shifting take...
3,386
Hello, I'm currently programming a MicroLogix 1400 in RSLogix Micro, and I'm trying to put data into FIFO queues. Would you know how to use the...
5,084
