FFL Instruction, use without having to toggle it's EN bit?
jds8086
Jan 2020
Kansas
42
EDIT: I suppose i should mention, RSLogix 500 V8.40, SLC 5/04 (1747-L542C)
Is there is a way to use the FFL instruction in a way that doesn't require its EN to have to toggle between true/false for it to load the next value? I have it in a subroutine that runs conditionally (logging events that are to be read via OPC and stored in a DB). Each "log-able" condition is checked in another subroutine that runs unconditionally, when a condition is met, JSR -> FFL subroutine, then it returns to continue checking other log-able conditions. It is important that each condition is checked every scan and stored in the buffer if true (hence why it's in it's own subroutine so that I can JMP to and return to continue evaluating other conditions).
No, but that doesn't mean you can't reset the .EN to 0 on a rung or branch before each FFL execution, and then execute the FFL unconditionally.
šŸ™ƒ Ever spend hours on a problem, give up and ask, then when you get the answer you just want to hide :ROFLMAO:
Thank You!
That's actually similar to a problem posed to a colleague of mine who went through RA PLC programming training. How can you make a single, standard counter instruction count the number of PLC scans with one rung of code?
Code:
|                         +-----CTU------+  My_Ctr.EN
|-------------------------+ CTU   My_Ctr +----( U )---|
|                         + PRE 99999999 +
|                         + ACC        0 +
I'd answer that, but I am busy hiding just now.
P.S. I know you got it, but I already found an example using BSR (similar to FFL i.e. uses Control R-file element).
We are converting an RSLogix5 PLC code to Siemens S7. Looking for the S7 instruction that replaces RSLogix5 FFL instruction.
2,324
Could someone please show me how AB FFL/FFU works in RSlogix 500. I can get data in the FFL just can`t get it out.:shock:A small sample of code...
12,809
I've been reading a LOT of the past topics, and A-B Knowledgebase, on the FFL/FFU instructions, but I still don't understand a couple of things...
6,705
I'm having trouble finding the control block length for the FFL instruction, and I'm really not sure how to find it. On the component it lists...
4,111
I have a project that is loading pallets into 10 test bays and then unloading them when the test is complete. I am using an array to store which...
171
