FIFO Load/Unload in RSLogix 5000
Jasondelane
Mar 2015
Florence sc
221
I just want to make sure I have this straight.
I have 7 saws all in line, each with a valve and pneumatic cylinder to move it up or down. I will have 3 or 4 different configurations to assign based on the type of log I'm cutting. Each valve is assigned a bit in an INT. So down, down, down, up, down, up, down will be 1110101. Each configuration will have a momentary switch assigned to it. As the log is traveling on the infeed chain, the operator will decide which configuration to use and press the button, which will MOV the INT into a temporary register. When the log is kicked into the deck and the chains advance, I will FFL the temporary register into a FIFO with 4 "positions" and FFU the previous configurations into their new "stage". At the third stage, when the encoder for the deck chains =90, the current FIFO Stage 3 will be activated and the saws will move into position. The fourth stage will unload and the entire cycle will continue each time the deck is advanced.
Do I understand the concept correctly?
I ended up dropping the FIFO and using 4 COP instructions in parallel. This greatly simplified the operation. Thanks for the tip though.
Yes, this is a project for school, and I'm not looking for anyone to do my work for me. What I would like is some clarification on using FIFO load...
2,361
Looking for more information on FIFO No one seems to have much information this instruction Would like to see a ladder with FFl and FFU More than...
6,896
Help Can someone help me. I am trying to use the load/unload command to move an interger value through the buffer. I cant seem to get it working...
2,253
I am new to RS Logix 5 - can anyone help me with a little example of a FIFL and FIFU code. When I make an input I want to capture the data and...
2,582
I have a camera system in a die that I am writing the program for. I have two tracks and capture two consecutive parts. The part out locations...
5,271
