Find Maximum/Minimum Integer
obi1987
Jan 2014
lahore
114
I assigned different values to pump(1,2,3) and these numbers I assigned to pump is status of pumps.Now i want to do which comes in first will first off.So how i can find the Maximum and Minimum of Pump states?
You didn't mention what your PLC make and model is.
Without that information, it is hard to advise the best method.
Max := Pump1
If Pump2 > Max then Max:= Pump2
If Pump3 > Max then Max:= Pump3.
Do the same for minimum.
For large quantities in an integer array you can use a SORT. Then the min and max are at each end of the array.
Hi all, I'm not too familiar with SCL programming and I need some guidance on writing a simple code in SCL that scans through a given number...
4,749
Hi All i have a trouble find Maximum of 30 Temp Transmitters can any one help me out with this?? So that we can use the maximum value and use it...
3,651
Hi All, Wondering if anyone has a source for information about products with problematic production runs from allen bradley/rockwell. Ive seen...
129
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
163
I have tested every screen and no single screen individually has this fault pop up, but when I compile and send to the PanelView it comes up. If I...
194
