First scan bit in Klockner Moeller EASY PLC
If there isn't, make yourself one....
|                         B          A       |
| | B | |
"A" will only be true on the first scan
Universal only if the bits used on the A and B outputs are "non-retentive" through a power-cycle, or operating mode change.
On Allen-Bradley PLCs, a "pre-scan" automatically resets all non-retentive outputs, resets non-retentive timers, etc.
This must happen in order for A to be turned on on the first "proper" scan following the pre-scan.
On some makes of PLCs, you have a choice of retentive bit memory, and non-retentive bit memory. Of course you would need non-retentive memory for A and B.
If all of your internal bits are retentive, then you would definitely need a "first-scan" status bit from the processor, and there'd be no need to "roll-your-own".
Hello. Does anyone know the equivalent of the first scan bit in a L32ER compactlogix? Do o need to obtain it via GSV? I’m looking to regain...
462
I want to know how to make a flip flop rung that will change states every scan. This is for a fast sequencer. Is there a special bit similar to a...
2,192
Dear Sir, Can you please tell me how to use the first scan bit, S2:1/15 in RsLogix 500 to Prevents the latch output to be ON when the power...
22
10,281
hello all, I am trying to set up a latch bit like this S:FS----- true condition------OTL. I tried in rs emulator and it the bit latches but in...
1,850
Do we have to enable the first scan bit somewhere in compact logix? For some reason my S:FS is not working? Also, if you want to have the CPU...
6,809
