Fix32 v6.1 -> iFIX v5.5 VBA Problem Scripts
JElder
Apr 2011
Aberdeen
23
Good Morning,
This is my first post and my first real exposure to GE and the Fix/iFIX environments so please bear with me.
I am currently in the process of migrating a Fix32 v6.1 system (WinNT) to iFIX v5.5 on Windows 7 32 bit / Professional.
I have converted the database (PDB) over and imported it in to iFIX.
I have changed the driver from ABR to IGS.
I have configured IGS with the IP addresses of the 2x PLC's it will be talking to.
I have converted all the graphics from the old ".odf" format to the new ".grf".
And thanks to the Migration Tool suite I have converted MOST of the VBA script associated with the pictures over to the new iFIX syntax.
However (and there always is a however), there are just a few scripts that need ironing out and I'm hoping this is where the e-Forum will help me
I ran through all 303 graphics to see what code was causing issues and I now have a record of it so here goes. Apologies for the length of this post.: -
Shell "HTD" + " " + -CG, 1 'RUNTASK HTD -CG "Aeration Blowers"
Exit Sub
ErrorHandler:
HandleError
Shell "WORDPAD" + " " + "SINGLE", 1 'RUNTASK WORDPAD SINGLE
Exit Sub
ErrorHandler:
HandleError
'iFIX Global Variable Object Created 'DECLARE #TASK STRING GLOBAL
'User.g_varTASK.CurrentValue = ""C:\PROGRAM FILES\VERITAS SOFTWARE\BACKUP EXEC"" '#TASK = "C:\PROGRAM FILES\VERITAS SOFTWARE\BACKUP EXEC"
'User.g_varTASK.CurrentValue = User.g_varTASK.CurrentValue + "\SYSTEM\BESTART.EXE" 'STRCAT #TASK "\SYSTEM\BESTART.EXE"
Shell User.g_varTASK.CurrentValue + " " + "SINGLE", 1 'RUNTASK #TASK SINGLE
Exit Sub
ErrorHandler:
HandleError
On Error GoTo ErrorHandler
'DataEntry Type = Numeric
'DataEntry OPRLO = 0.
'WizardName=DataEntry
Dim vntLow As Variant
Dim vntHigh As Variant
Dim intReturn As Integer
Dim blnFetch As Boolean
If blnDataEntryFrmFlag = True Then
Exit Sub
End If
GetFormNumeric
FetchLimits "Fix32.FIX.H3_MD00X_SBYSP_SAI.F_CV", vntHigh, vntLow, intReturn
Numeric.GetTheLimits H:=vntHigh, L:=vntLow
blnFetch = True
Numeric.IsAlpha A:=False
Numeric.GetTheVars A:=1, B:="Fix32.FIX.H3_MD00X_SBYSP_SAI.F_CV"
Numeric.Show 'DataEntry OPRHI = 0.
Exit Sub
ErrorHandler:
HandleError
'NO CONVERSION CURRENTLY AVAILABLE ---> 'DataEntry Type = MenuItems
'DataEntry MenuItem1 =
'DataEntry MenuItem2 =
'DataEntry MenuItem3 =
'DataEntry MenuItem4 =
Exit Sub
ErrorHandler:
HandleError
Dim varCHK As Single 'DECLARE #CHK NUMERIC
ConvertRT_CheckRights "SL DRYER SPT ENTRY", CInt(varCHK) 'CHECKRIGHTS "SL DRYER SPT ENTRY" #CHK
If varCHK = 1# Then 'IF #CHK == 1.0
AcknowledgeAllAlarms ' ALARMACKALL
Else 'ELSE
MsgBox "Login As Operator Or Above" ' NOTE "Login As Operator Or Above"
End If 'ENDIF
Exit Sub
ErrorHandler:
HandleError
Private Sub BUTTON13_MouseUp(ByVal Button As Integer, ByVal Shift As Integer, ByVal X As Double, ByVal Y As Double)
'RUN WORDPAD SINGLE
Exit Sub
ErrorHandler:
HandleError
End Sub
';Script for While Down follows
';HINT: Use timer events for WhileDown functionality
varUP001 = 1 '#UP001 = 1
'NO CONVERSION CURRENTLY AVAILABLE ---> 'CRITICAL
Dim varSTORE As Single 'DECLARE #STORE NUMERIC SCRIPT
Dim varHIGHL As Single 'DECLARE #HIGHL NUMERIC SCRIPT
Dim varLOWL As Single 'DECLARE #LOWL NUMERIC SCRIPT
Dim varCOUNT As Single 'DECLARE #COUNT NUMERIC SCRIPT
Dim varSTEP As Single 'DECLARE #STEP NUMERIC SCRIPT
varCOUNT = 0 '#COUNT = 0
varSTORE = ReadValue("Fix32.FIX.G-MIT700-SETPOINT.F_CV") 'GETVAL FIX:G-MIT700-SETPOINT.F_CV #STORE
varHIGHL = 8# '#HIGHL = 8.00
varLOWL = 0# '#LOWL = 0.00
varSTEP = 0.01 '#STEP = 0.01
L1: '&L1
If varCOUNT < 10 Then 'IF #COUNT < 10
If varSTORE + varSTEP <= varHIGHL Then ' IF #STORE + #STEP <= #HIGHL
varSTORE = varSTORE + varSTEP ' #STORE = #STORE + #STEP
Else ' ELSE
varSTORE = varHIGHL ' #STORE = #HIGHL
End If ' ENDIF
Else 'ELSE
If varCOUNT < 19 Then ' IF #COUNT <19
If varSTORE + (varSTEP * 10) <= varHIGHL Then ' IF #STORE + (#STEP * 10) <= #HIGHL
varSTORE = varSTORE + (varSTEP * 10) ' #STORE = #STORE + (#STEP * 10)
Else ' ELSE
End If ' ENDIF
Else ' ELSE
If varCOUNT < 28 Then ' IF #COUNT <28
If varSTORE + (varSTEP * 100) <= varHIGHL Then ' IF #STORE + (#STEP * 100) <= #HIGHL
varSTORE = varSTORE + (varSTEP * 100) ' #STORE = #STORE + (#STEP * 100)
Else ' ELSE
End If ' ENDIF
Else ' ELSE
If varSTORE + (varSTEP * 1000) <= varHIGHL Then ' IF #STORE + (#STEP * 1000) <= #HIGHL
varSTORE = varSTORE + (varSTEP * 1000) ' #STORE = #STORE + (#STEP * 1000)
Else ' ELSE
End If ' ENDIF
End If ' ENDIF
End If ' ENDIF
End If 'ENDIF
varCOUNT = varCOUNT + 1 '#COUNT = #COUNT + 1
Call WriteValue(CStr(varSTORE), "Fix32.FIX.G-MIT700-SETPOINT.F_CV") 'SETVAL FIX:G-MIT700-SETPOINT.F_CV #STORE
'NO CONVERSION CURRENTLY AVAILABLE ---> 'ENDCRITICAL
'Goto L1 'GOTO L1
';On Down Script; DECLARE #UP001 NUMERIC PICTURE
varUP001 = 0 '#UP001 = 0
Exit Sub
ErrorHandler:
HandleError
CloseDigitalPoint varNAME_S 'CLOSEDIG #NAME_S
ClosePicture "DM_YESNO"
Exit Sub
ErrorHandler:
HandleError
Shell "HTD.EXE" + " " + "-cg 'CHART8'", 1 'RUNTASK HTD.EXE "-cg 'CHART8'"
Exit Sub
ErrorHandler:
HandleError
ClosePicture "PC_33" 'CLOSEPIC PC-33
ClosePicture "CC_33" 'CLOSEPIC CC-33
OpenPicture "CC_33" ' OPENPIC CC-33
Else 'ELSE
OpenPicture "PC_33" ' OPENPIC PC-33
End If 'ENDIF
Exit Sub
ErrorHandler:
HandleError
Dim varVAR1 As Single 'DECLARE #VAR1 NUMERIC SCRIPT
varVAR1 = ReadValue("Fix32.FIX.A-SETPOINT-GRIT-TIMER4.F_CV") 'GETVAL FIX:A-SETPOINT-GRIT-TIMER4.F_CV #VAR1
If varVAR1 < 10 Then 'IF #VAR1 < 10
varVAR1 = varVAR1 + 1 ' #VAR1 = #VAR1 + 1
Call WriteValue(CStr(varVAR1), "Fix32.FIX.A-SETPOINT-GRIT-TIMER4.F_CV") ' SETVAL FIX:A-SETPOINT-GRIT-TIMER4.F_CV #VAR1
End If 'ENDIF
ConvertRT_Pause 0.5 'WARNING: Please check the definition of ConvertRT_Pause in ScriptConvertRT.bas, which should be imported into Project_User, for important guidance. 'PAUSE 0.5
GoTo 4 'GOTO 4
Exit Sub
ErrorHandler:
HandleError
Private Sub BITMAP1_MouseDown(ByVal Button As Integer, ByVal Shift As Integer, ByVal X As Double, ByVal Y As Double)
varUP000 = 1 '#UP000 = 1
varSTORE = ReadValue("Fix32.FIX.G-SOUNDER-TIME.F_CV") 'GETVAL FIX:G-SOUNDER-TIME.F_CV #STORE
varHIGHL = 30 '#HIGHL = 30
varLOWL = 0 '#LOWL = 0
varSTEP = 0.1 '#STEP = 0.1
L1: '&L1
Else ' ELSE
End If ' ENDIF
Else 'ELSE
Else ' ELSE
End If ' ENDIF
Else ' ELSE
Else ' ELSE
End If ' ENDIF
Else ' ELSE
Else ' ELSE
End If ' ENDIF
End If ' ENDIF
End If ' ENDIF
End If 'ENDIF
Call WriteValue(CStr(varSTORE), "Fix32.FIX.G-SOUNDER-TIME.F_CV") 'SETVAL FIX:G-SOUNDER-TIME.F_CV #STORE
'Goto L1 'GOTO L1
';On Down Script; DECLARE #UP000 NUMERIC PICTURE
varUP000 = 0 '#UP000 = 0
Exit Sub
ErrorHandler:
HandleError
Many thanks,
JElder
Ok, a bit more information on this matter and hopefully some progress.
Regarding this script: -
"Shell "HTD" + " " + -CG, 1 'RUNTASK HTD -CG "Aeration Blowers"
Exit Sub
ErrorHandler:
HandleError"
As Classic Historian is no longer in use, I will have to establish an alternative using Proficy Historian.
As for this one: -
"Shell "WORDPAD" + " " + "SINGLE", 1 'RUNTASK WORDPAD SINGLE
Exit Sub
ErrorHandler:
HandleError"
I can easily modify that to open Wordpad but I don't see what purpose that would serve, unless opening a log file to which data was being continually written.
Finally I believe this script is checking the user's rights:-
Else 'ELSE
End If 'ENDIF
Exit Sub
ErrorHandler:
HandleError
I think the equivalent in iFIX would be: -
Public Sub SecurityGetUser()
Dim Result As Integer
Dim UserID As String
Dim GroupName As String
Dim UsreInfo As String
System.FixGetUserInfo UserID, Username, GroupName
MsgBox "Login Name; " & UserID & vbCr & "Full Name; " & UserName &vbCr & "Clearance Level; " & GroupName
End Sub
How am I doing so far?
*update*
I have managed to get WordPad to execute using this KB article from GE. However, whenever I click the button to execute that script, I get an error message pop up box which says "WorkSpace Application - Error Number : 0 (0)".
WordPad still opens fine and there are no errors showing up in VB.
Any ideas as to what is causing this?
*update*
Solved.
There was a missing "Exit Sub" statement šŸ™ƒ
All that remains now is to setup Historian but I can't seem to convert any of the old .H04 files as I'm missing the executable "HGRPexp.exe". I wish to use the Historical Pen Group Export Utility followed by the Historical Pen Group Convert Utility, however I am missing the executable "HGRPexp.exe".
Why would this be when the other Migration Tools function correctly?
How do I then configure Proficy Historian to record data as it was before in the Fix32 system?
Good day folks, i have a question, maybe have someone the installation for LNI drivers (lonworks network interface) for fix32 i need it for an...
1,069
We were just quoted $7000CAD to upgrade a Fix32 Ver 6.X to V7.0 then to iFix. This price seems more like the cost of the iFix package rather than...
3,806
I am involved with a plant move from one location to another. Company A sold an old process to Company B . Company B is now discovering all the...
7,132
Hi guys. I have a problem regarding remote node database. There is a remote node and its datbase available in PDB folder with node name as name...
6,067
I have a a PLC-5 system that is connected to a Windows 2k PC that is running Fix32. I was called to reload the program onto the PLC-5 and I did...
1,300
