Fix32 v7.0 data export to excel
Hal9000
Jun 2010
London
140
Hi
A customer of mine is running Fix32 v7.0 and has asked if there is any way the historical data can be exported into excel. As it stands the data is only being represented on trend displays. I've had a good look around and can't see any export facility.
The data seems to be logging to .h24 files, one file per day in the c:\fix32\hdr folder.
Is there any export tool available that can do the conversion to say .csv?
Best regards
Hmm, I haven't worked w/ Fix in a few years, wasn't there an application HTD2CSV.exe to do just that? Might need to check w/ your GE rep on getting a copy.
Thanks Dravik, I'll ask the question. They'll probably say they don't support the legacy product. Worth asking though.
Many thanks.
Moving forward, If you don't want to keep logging like that, You can setup ODBC logging to SQL or somesuch. I'd have to look and see if I still have the manuals to know how that's setup.
We used both to enable both the internal charting and long term storage.
Hi. I have Fix32 system where I have many blocks like VLV...PMP..etc which have many internal signals and addresses. How can I extract these...
2,527
I have three CompactLogix controllers from which I need to acquire data and display on my SCADA. The data originating in the PLC is off by a...
2,070
I am working with GE FIX32, version 7.0. I have migrated an application using the older 6.x ABR driver, from WinNT to Win2K, and have now moved...
7,592
I have a a PLC-5 system that is connected to a Windows 2k PC that is running Fix32. I was called to reload the program onto the PLC-5 and I did...
1,300
Good day folks, i have a question, maybe have someone the installation for LNI drivers (lonworks network interface) for fix32 i need it for an...
1,069
