Fixes error indication "system configuration mismatch" the module of PLC VERSAMAX CPU
codientt
Aug 2010
ha noi
I'm having the case of PLC VERSAMAX GEFANUC error. It is the fault system configuration of the module is not compatible. Although I was rather good and completely new module, but still this error. Want you to teach me how to fix this
Please help, I have the same problem!!
I used a new module PLC IC200CPU001 of VERSAMAX GE FANUC and it work ok but when the energy turned off and comeback turn on the PLC go fault "System Configuration Mismatch" please help me, I don´t know how to fix it
System configuration mismatch means the actual modules installed don't match the hardware configuration file. It could be that your backup battery is dead. It could be that the PLC is set up to load hardware configuration from flash memory upon power-up and there is a blank harware configuration file in flash memory.
Or...
It could be that the module has a hardware jumper that does not agree with the software configuration.
More details like part numbers used and how it is configured in software just might help someone have better information for you.
Siemens S7/TIA v18: "Remote" updates/bug fixes to PLC code & HMI screens..... Hi, The PLC application I'm working on will soon be delivered to...
587
In these times of isolation I thought it might be fun for us to own up to past temporary fixes that we, for 'whatever reason' never got back to...
2,701
Hi I have customers who want to update server 2003 SP2 with all the post-SP2 hotfixes. The question is, how easy and time consuming is that? I...
1,694
For those of you in ST5000 and develop your logic in ST. AB/Rockwell has finally fixed the long ST hangup bug in v27 release. (bug was when you...
2,713
Problem 1. I am unable to input the "I" or "O" prefixes to register numbers. Example: I can't enter "I5.02" or "O1.02" as the input and output...
4,927
