Floating Decimal Point
fusionworks1
Mar 2009
Slave Lake
Equipment- AB HMI PV600 2711-B6C20 Control Logix 1769L32E
Software- RSlogix 5000 and Panelbuilder 32
Problem- I have an analog signal back to processor and I am using a CPT instuction (Local6.I.Ch2Data-4000)/*1000/1600 which is calculating my data and putting it into a DINT N7[2] which is the Tag for the HMI. The number I am recieving is for example 384 but the actual proper value I want to display in the HMI is .384 Any suggestion out there
Ladies & Gent's, I am reading a floating point number from a Seimens RWF40 controller(PV) modbus address 30000 IEEE_754 format. I want to...
2,726
I’m using a 05 PLC which cannot handle real (floating point) numbers. The operator must enter the cut length into the C-Micro panel. (I used a...
3,591
I am working with a flow meter that registers floating point values through a pipe and want to first convert that to a decimal value, and second...
7,450
Hi there, Does anyone know how to limit the # of decimal places of all floating integers displayed on the HMI? I want to display one decimal...
7,478
RSLogix 500 FTVS-ME I have a floating integer that I only want to go 2 places to the right of the decimal point(100th) but I can't find the...
1,662
