Floating Point Math Anomaly
dmmons
Sep 2011
South Jersey
54
Processor: Micrologix 1400
When doing subtraction using floating points (SUB F34:0 F94:10 F94:15 ) I am subtracting two values which have a maximum of 3 decimal places and always end in either 0 or 5.
For instance 12.440 - 11.445
I would expect and answer of 0.995, instead I get an answer of 0.9949999.
I suspect it is something to do with floating point math, but can't quite figure it out. Rockwell tech support is also working on a solution.
Anyone here have any ideas?
Try wikipedia of 'floating point'. Those are 32 bit single precision numbers on the 1400. Every floating point number has a limited amount of precision: 24 binary bits is around 7 decimal digits. If you need fixed precision you'll want to use integers: the 1400 supports 32 bit integers (L).
So you don't consider 0.994999 to be close enough to 0.995 to be useable ? It is my understanding they landed men on the moon with far less precision than that in their maths!!
Yes, but we didn't land close enough to get "Two cheeseburgers and a Big Mac to go" :)
That is a blast from the past, rootboy. I never could land that goofy thing without turning it into a bunch of little line segments!!
Keith
Keith
I wondered how long it would take for someone to get the reference. I never managed to land the darn thing either! :)
Remember the size of the paper tape program? It took 43 minutes to load it up (and lord help you if you were the guy to take McDonalds out with your lander).
If the imprecision bugs you do the same math with integers or longs (use the numbers * 1000).
Each computerized method of storing numbers has its own strengths and weaknesses. They are tools. Study them. Use the best one for the particular job you are doing.
Use fractions where it takes 3 integers to represent a number. There is the whole number, the numerator and the denominator. Fractions are precise. Where things go wrong is when you try to convert the fractions to floating point. Then 199/200 still gets converted to 0.9949999
Logix 5562, f/w rev 20
I'm working on a math-heavy project on CompactLogix L45 (Rev. 20) and am running into some issues with a calculation to determine the angle...
3,952
am using s7200 cpu222 my cpu support cosine,sin,tan function....but i neeed arcsin(sin-1) function how can i obtain it?????
2,266
Hello, I'm working with an AD DL05, integer math only. I've got a C-more micro for an HMI. I need to input inch dimensions for a cut to...
19,166
Hello everybody I'm new to plc programming and i'm trying to program some simple math operations to convert some measurments for a project. The...
5,603
Does anybody know how the floating point math works in the ML 1200? I'm trying to divide 2 numbers, can i get a result accurate to 1 decimal...
3,203
