Floating point to integer
rojay
Sep 2011
Cleveland
In RS500 can I multiply a Floating point by 10 to get rid of the decimal? Ex: Source A(11.436) x Source B(10) = N7:0(114), or will I still get a float with the decimal shifted to the right
The result will be rounded based on the remaining decimal places. In your specific example you would get 114. If not express the second value (10) as 10.0
Hi eveyone. I need transfer signal from system 1 to DCS via modbus. System 1 only can send 32 bit floating point. DCS receive 16 bit integer. How...
20
10,639
Does anyone know of any such PLCs? Usually I'm lazy and don't want to think about precision and overflows.
20
7,018
I have noticed in one of our PLC5 programs there is a copy instruction that copies a integer into a floating file. The integer value being copied...
17
9,173
I have a ML1400 Series B controller which is integrated with Wonderware via Modbus TCP. I have a flow totalizer in the ML as a floating point...
6,880
Hello, I'm working with an AD DL05, integer math only. I've got a C-more micro for an HMI. I need to input inch dimensions for a cut to...
19,129
