Flow Computer - Idec FL1E
nikmis
Sep 2012
Alberta
I am trying to create a simple flow computer using an Idec FL1E smart relay. It has HSC inputs and I would like to use them to read the pulse from the meter and display a flow rate on the screen. I have experience with simple ladder programming but nothing like this. Help anyone??
This is a scaling issue. The solution is in algebra:
You meter should have a rating of X gallons per pulse. 1/gal/pulse = pulse/gal
Your PLC should allow you to read the frequency of the input, pulses per second.
pulse/sec x gal/pulse x 60sec/min = gal/min
I get the math bit, that will be the easy part. I am having a hard time pulling the frequency from the input. There are limited functions on this relay unit. A higher end plc would probably be easier but this is what i have to work with.
Has anyone installed Hp laserjet pro 4203 to OMNI 3000 or 6000 via ethernet..Is there a specific Config? I have a problem..Please advise
62
Anyone happen to be familiar with ROC 800 flow computer hardware? I'm new to the ROCLINK 800 programming software and I have a quick question...
824
Hi Experts Thank you very much for your support and help. I am completely new to MODBUS, I have S7300 where CP341 is installed to send and...
1,711
Hopefully this is allowed here as this isn't really a PLC but I've seen some people posting about it in the past that seemed to know this machine...
1,790
Hi everyone, Has anyone on the Forum used the Prosoft Flow Computer before? What was your opinion of it? I am quoting a well pad job and was...
1,842
