Flow switch for fire hydrant in combined network
Charbel
Jan 2012
Beirut
307
Dear,
we are having a combined fire and irrigation network and the idea to know where fire hydrants are opened is to put a flow switch on each fire hydrant line.
If flow switch is switched on, then the fire hydrant is being used, this will be used to know that there is a fire. When fire occurs, all irrigation facilities will be stopped and fire pumps will start. I was thinking of putting safety RTU's to take the signals from the flow switches. Maybe putting one RTU for a set of flow switches and connect all RTU's through a safety network.
What do u think first of all about this idea? and what is the criteria of combining flow switches, is it per zone? or any advice concerning wiring constraint? or any other advice?
Thanks a lot!
charbel
RTU in combined fire irrigation network
Dear,
I have considered that each RTU can cover a area having a circle of diameter = 500 m, find below a snapshot of the system? What do u think? all the RTU's will be connected to the pumping station dual redundant Safety PLC.
Im having trouble locating a flow switch that can sense liquid nitrogen. I dont need to know the flow rate just whether it is actually flowing or...
2,033
Have any of you all ever brought a flow switch with a 1" process connection that did not fit in a 1" rigid tee? I mean, I guess I could have...
3,243
We have a water heating system for a pasteurizer with 2 in-line heaters connected in series. I need to insure that there is water flow in the...
4,289
dear, I am working on a design of pumping station consisting of three (3) pumps two duty and one standby. I was wondering what is better to...
5,003
Project: install an air flow switch to monitor cfm and remote start one of 4 compressors ranging from 30cfm to 150cfm, depending on the demand...
2,078
