For Allen Bradley platform, without PLC, can I use an .ACD file to create a new HMI ?
David0531
Jan 2022
Calgary
No physical plc and only have some PLC program. want to learn HMI programming by myself.
Welcome to the forum.
My boss told me that you can and how to do it,
create your hmi screen and link to the plc address.
when you compile the program and download it to the hmi, you must link the terminal to the correct ip address.
THIS is from memory of what he told me and i have been to busy working on the lines to try it. IF i am incorrect, someone please correct me.
regards,
james
Depends on HMI brand-model.
HMIs that program with Allen Bradley Factory Talk View can read a .ACD file for offline programming.
Automation Direct C'More HMIs require the .L5K ascii version of the .ACD file. (This s/w is free and seems pretty good to learn on.)
YMMV depending on other brands.
If using View Studio, yes you can. You will need to add the location of the ACD file to the Communications Setup Tab in the project tree under the RSLinks Enterprise tab. This will add the tags from the ACD file to the tag browser in the offline section, where you can pick them for your objects.
See Screen shot.
As stated, depends on the HMI. To add, you can use Emulate. I have tested Emulate 5000 for both FTView and Ignition. It doesn't have to be local either. Emulate can be hosted on a separate box.
If you want to learn the HMI side, I strongly recommend Ignition over FactoryTalk. It's a much better platform, and free for you to develop and run for 2 hour demo (you can reset this demo as much as you want)
Any one give solution for this fault. We are using AB Gaurd logix controller(5573s), resent days we are facing major fault in controller...
85
Hi how's it going. Was just wondering if someone could help me out. Recently one of the guys over on the LinuxCNC forums put me onto getting an...
355
Hello, Does anyone have one of these cables and willing to open the case so I can see the cable connections inside? 2707-NC5 I have sourced the...
105
Currently trying to find: micrologix ethernet interface 1761-NET-ENI AIC to micrologix 761-CBL-AM00 Ser C cable These are used for micrologix...
141
in allen bradley kinetix 300 drive first E31 error shows after resting drive E11 error occurs need solution to reset E11 fault code
188
