Foxboro FBM 233 Modbus Port
CanSpellPLC
Sep 2020
USA
Hello everyone!
I've got a question for the Foxboro gurus out here. Does anyone know if its possible to change the TCP/IP port for Modbus RTU communication on an FBM 233?
For reference, the 233's use the standard TCP/IP port 502 for Modbus communication, but we have a device that requires the secure protocol over port 1502.
I skim read a proposal for a secure version of the Modbus protocol some years ago, but have seen very little reference to it since. I wasn't even sure if it was adopted or not. To be honest, I don't recall much of that skim read.
So I'm speculating that just having a port at1502 is not likely to fulfill the requirements for secure Modbus - there's likely to be additional handshaking acknowledgements that precede actual communications. So if a device is not firmware equipped to support a secure Modbus protocol, the presence of a port at 1502 is not likely, in and of itself, to support a secure protocol.
@danw
d'oh...
that's a really good point, and should have been obvious on my side. I'll need to see if Foxboro even has the ability to perform handshake/authentication requirements on their side before I even consider trying to change the port number.
thank you so much!
Currently waiting for Schneider Customer Support...:D ... meanwhile: Brand new ABB ACS355 with FPBA-01 Profibus DP adapter connected to a six...
7,729
Does anybody know where I could get some training on an FCP270 system? ideally in the UK? Equally, where there is any reference manuals online?
999
I have a server with Foxboro I/A. It is currently logging data. The Foxboro tech installed the following software on this machine: Matrikon OPC...
2,545
Hello, I have been tasked with replacing 16 aging Foxboro 762CNA-AT controllers (as well as some other process displays) with something more...
2,260
Good Day Friends! Please, who worked on Foxboro DCS AW70 H90 Server? What software is used for its configuration? Thanks in advance
1,226
