frequency inverter waveform
tny
Jun 2005
usa
105
hi; i wonder how does an inverter works and what is the generated wave form for the motor?
i mean if i adjust the output set value to 50 hz, does the inverter generate a continous 50hz sinusoidal wave or discrete signal?
thanks.
Hello tny;
Here is a link to a good basic document on VFDs.
http://www.kilowattclassroom.com/Archive/VFDarticle.pdf
Basically, a VFD takes a constant frequency voltage input (AC, 50 Hz), redresses it to a DC voltage, and uses SCR/IGBT bridges to output a variable-frequency sinusoidal signal to the motor. Since the rpms of an AC motor are proportional to the frequency of the voltage applied to it, the speed will vary as the frequency.
Others are welcome to correct or modify the above information of course.
Hope this helps,
Daniel Chartier
The description given above about the incoming AC to a VFD being rectified to DC and filtered smooth is exactly correct.
The output inverter stage consists of six solid state switches, usually IGBT's, two for each motor lead. As a result, each motor lead can be connected thru these switches to either the + side of the DC bus or the - side. The voltage on this DC bus is relatively constant being equal to the peak value of the incoming AC voltage. So, for 460VAC, that would work out to around 660VDC.
The inverter output section of the VFD is not sending anything resembling a sine wave to the motor since the only thing these switches can do is turn on or off. The result is a high frequency train of pulses all of which have a peak voltage equal to the DC bus. The only thing that varies in these pulses is the amount of time that they stay on, or their pulse width. Hence the term, Pulse Width Modulation or PWM.
This pulse train alternates back and forth between being positive pulses and negative pulses thus attempting to create the alternating phases of an AC wave. It is up to the inductance in the motor to take these high frequency variable width pulses and reformulate in the current something that approximates a sine wave. This sine wave, with varying degrees of distortion is what the motor runs on. Note that a sine wave never does appear in the voltage--it's nothing but a train of pulses.
That explains why the motor squeels and sings on inverter power. Those pulses are actually disturbing the magnetic components of the motor and creating noise that you can hear. That also explains why motors tend to run warmer on inverter power--they are busy integrating these pulses as well as trying to produce torque in the shaft.
Since the VFD electronics determine the switching times of the inverter switches, it is relatively easy to create the equivalent of variable voltage and variable frequency so the motor will develop torque at variable speeds.
These's a lot more to it than that, but that's the basics.
Hope that gives you a start on understanding VFD's.
Good thread... I never quite understood how an inverter actually simulated a Sine wave, so the PWM stuff caught my attention.
I think my VFD knowledge comes more from DickDV's brain than from any other source. Thanks Dick.
Hi, I have a problem with a "mobile" equipment with a frequency inverter. The equipment trips the residual current breaker. I have bee reading a...
3,295
Hi Guys, I am using FR S520S 0 2k EC mitsubishi and when I run the motor forward, the frequency is the same with my analog output but when I run...
1,211
My job is to try to control brushless servo motor with frequency inverter. I just connected such motor to a frequency inverter and I tried running...
3,074
may you please explain that programm im not very familiar with statement list.
1,294
Hello everyone For my work I need to link a Siemens S7-300 (CPU is 315) to a Siemens Sinamics G120 with profibus. The thing I know is that I...
2,072
