Frequentie of a HS Input in CCW
nightline
Feb 2010
Prinsenbeek
425
Gents,
I've a Micro 830 on a 4 wheel driven vehicle, and need to calculate the wheel speed. Every wheel has a Hall sensor connected to a High Speed Input.
Wheel 1 is connected to HS input 0
Wheel 2 is connected to HS input 2
Wheel 3 is connected to HS input 4
Wheel 4 is connected to HS input 6
In the sample code software of CCW is a program which should do the task which I need.
I copied that program into my project, defined the parameters and programmed the time interrupt of 1000 ms.
Unfortunately it doesn't work...
Can anyone me help me with this?
Thanks!
Jack
Gents,
I had a chat with a support engineer and he pointed me to the thing what was wrong.
I programmed only the HSC instruction in the Interrupted program, which is only to reset the HSC instruction in the normal Program which uses the same Tags.
So it's working now.
Regards,
Jack
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
78
Hello, I'm looking for a dirt cheap digital display + input, that would be wired to an analog input and analog output. This would be for my home...
260
Hello, I am trying to read a barcode scanner input using a cognex dataman 280 barcode reader, store it another string, the compare with another...
75
All, I have a PowerFlex 525 driving an agitator motor. The goal is to have the agitator start automatically after a power loss or a comm loss. I...
90
413
