FT Diagnostic viewer not working
mrgees100peas
Aug 2016
vermont
24
For some reason FT Diagnostic tool is not working on our scada machine. The thing is that the IT guy setup FTView to be hosted in the scada but can be developed on from a different machine. When I run the client or even the screen on the development machine the FT Diagnostic Screen works as expected but when I open it on the scada machine all I see is a hash displayed where the activeX component should be. I'm thinking that either something is not pointing to the right direction/folder or that there is an issue with the activeX component. What say you guys?
FTView verion 12.00.00
You probably need to check your Diagnostics Setup. Usually found at "C:\Program Files (x86)\Rockwell Software\RSView Enterprise\DiagnosticsSetup.exe"
Hi, is there a way to change the time and date in the plc so they appear right in the diagnostic buffer. Also am I right in thinking the error is...
117
Hello to all, I hope everyone here is good! Does anyone have any recommendations for network diagnostics software? I have an AB Network, 4...
276
Hi, I'm trying to understand a couple of things with a feedback signals that are used in a SRP/CS that I'm working with. Quick disclaimer: I'm...
540
Hello, I have followed the "On_board Audit Demo" sample in FactoryTalk View Studio ME to add the functionality of exporting the Audit, Alarm, and...
1,160
I could use some help figuring out the layout of a Remote I/O channel Diagnostic Files in a PLC5 using RSLogix5. I've attached a screen shot of...
3,664
