FT View ME disable input
nettogrisen
Mar 2007
Here
383
Hi
Is there any way in FT View ME to disable the input to a numeric curser input field so that it still displays the value?
Because I want to type in values, but want to be able to lock it, so that only some people can.
Well why didn't you say so?
The only way that I have been able to achieve something similar, is to have a numeral display & numeral input together, with the numeral input completely transparent, and only visible under the required conditions.
Give that a try and see if that does what you want, unless someone else chimes in with another option.
Yeah, that was what I was afraid of.
It's just going to look very messy
You think? I have it so it is not noticable, but does require the knowledge of how it is done, or else one my get confused later....
Could you not put the input field on a screen that requires password access but send that value to a numeric display on the other screen ?
Yeah, I was thinking about that too, but ended up just putting the numeric displays on top of the inputs and grouping them.
2,241
I use the Global Connections feature to write the time from my PanelView Plus to my ControlLogix, and use the Seconds value as a watchdog to...
2,341
Hello, I have developed a Factory Talk View SE application and do not have any users or logins enabled. The system is auto logging out after...
4,375
We have an existing app and it uses a grouped transparent polygon global object to cover buttons and setpoints to disable them. There is no VBA on...
1,552
Hi An HMI has been running in WXP in RSview 32 works. I want to disable the keys Ctrl + Alt + Dlt. Normally in System > Start UP of Project of Rs...
1,682
