FTView: Execute VBA code from event
mateus
Jan 2017
RS
Hi there,
Is it possible to execute a VBA code using the 'Action' field in an event? Since FTView doesn't have the vbaexec command... If not, how to proceed?
Ps.: I'm migrating a RSView project to FTView, in RSView i was using the vbaexec command.
I'm not familiar enough with RSView to know how the vbaexec command works, but if you can give a little more specific detail on what you ultimately want to achieve, I might be able to help a little
FTView SE VBA is very different than RSView32 VBA. In a lot of ways, it's less powerful and harder to use in FTView than it was in RSView.
Long story short, no, an event cannot directly launch VBA code in View SE. In RSView32, VBA code could be "centralized" in modules that could be called from any object in the project. The vbaexec command could execute any subroutine you programmed in that central module, from any screen in the project, even events.
This is no longer the case. In SE, all vba code is tied to a specific display. There is no central repository for subroutines. You can fake this out and reproduce this functionality by setting up your runtime project to call up a display you've dedicated solely for VBA code. If you run the display as an overlay type, and then called it with the command "Display (your display name here) /ZA" this will call it up in cache so it won't be visible on runtime but will still execute the code.
Your event programming will have to be done in the vba code of this display. You can access it by right-clicking on an empty area of the screen and clicking "VBA Code" on the context menu.
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
40
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
185
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
237
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
102
Hi, I have an issue accessing tags in 3 of my plcs'. When I go to select a tag there is no folder drop down as can be seen in the photo. Any...
96
