FTView Graphic Import limitations?
phuz
Jun 2008
Mohnton, PA
1,044
I recently upgraded a PV1400e to PVPlus and the conversion utility was mediocre, at best. It missed a lot more things than I am used to and implemented a "Check and revise..." to many of the expressions as well as adding a "/(10**1)" to many of the numeric displays. Because the Find/Replace built into FTView Studio is borderline useless, I opted to export all of the displays to XML and use Notepad++ to Find/Replace within all my files, which worked GREAT! (Kudos, Notepad++). Unfortunately, upon importing the files back into FTView, the expressions were not updated. I chose "Create new" and "Update existing" and neither worked. So basically the import feature is also useless? Looking for some verification.
Import feature works whenever I've used it, but that's with doing a simple export from one, and importing to another. I've never tried editing with notepad... that may be your issue?
I agree that the find/replace and most modern features are either worthless or non-existent in FactoryTalk.
where do i find FTVIEW HMI Enhanced graphic as per attached HMI screen snapshot i had tried its library:scratch: object but they are not similar...
2,142
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
173
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
224
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
95
Hi, I have an issue accessing tags in 3 of my plcs'. When I go to select a tag there is no folder drop down as can be seen in the photo. Any...
92
