FactoryTalktotheHand
I'd just like to confirm this works, if I could.
In my project, I have 4 Alarm DINTs that I'm using for triggers at the bit level. If I set up those 4 DINTs in the alarm trigger setup, and set the trigger type to Bit, then....
When I set up the Alarm messages, do I assign the particular DINT to the Trigger field and the individual bit to the Trigger value?
So for instance, if I have AlarmWord[0] in the Trigger field and 3 in the Trigger value field, will that message appear when AlarmWord[0].3 is true?
