FTView Point - Trend pointer problem
tokar
Nov 2020
Somewhere
Hi guys,
I'm new here and I just started to work as junior automation engineer. It will be much more easier now I have access to this site. Wish me a luck! :)
I noticed a problem with trends in FTV PV 10 & 11. Mouse is not synced with trend pointer, so I can't access to some X-axis values or use slidebar. Maybe it's better to watch the video (LINK).
Sometimes it works, sometimes don't. I tried on a few different browsers, same problem (Chrome, Opera, IE, Edge, Firefox).
Thanks in advance! :D
Since this is a PV+, I assume it is a touch screen too. You may need to calibrate the screen.
I have had a few get way off, could not even select huge Push Button icons.
Edit:
boot the PanelView Plus and go in to the Configuration Mode.
Select Terminal Settings->Input Devices->Touch Screen->Calibration.
Touch the center of the target (+) each of the four times it appears on the screen
Start rant.. So in a previous gig a coworker setup a skid with FactoryTalk View point and I thought it was kind of neat being able to load a...
1,579
I have a client who has asked for a pop-up for each of their analogs, which will display the alarm values. The values displayed in the pop-up...
2,534
How can I record operator activity regarding change in tag values? (e.g. setpoint changes). I have not found it in Alarm & Event Server. The...
1,742
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
171
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
218
