FTView SE read PLC tag (RSLinx) in VBA
erghurt
Aug 2017
Alton
Hi there,
I have been looking in the forums for this and I saw a couple of examples but I still don't understand very well how to create a VBA script that will allow me to read a value of a PLC tag browsed from the RSlinx Enterprise file (Offline Tag File)
For the PLC I am using Studio 5000 V30.00
for the SCADA I am using FactoryTalk View Studio SE V9.00
What I am trying to do is:
1)Read variables from the PLC
2)Create a file (*.txt)
3)Write to that file the value of the variables
So far what I have is:
Dim File_System As Object
Dim File As Object
Dim Started as boolean
Dim File_Name As string 'this needs to change with date, any advice?
Dim Finished as boolean
Dim PLC_local_tag as integer
Started = ?????
Finished = ?????
PLC_local_tag = ?????? ' how do I read the value of a PLC tag?
If Started = 1 Then
Set File_System = CreateObject("Scripting.FileSystemObject")
Set File = File_System.CreateTextFile("C:\Users\Admin\Desktop\data\ " & File_Name & ".txt", True)
Else
End If
If Finished = 1 Then
File.WriteBlankLines ("2")
File.writeline ("==========")
File.writeline ("Number")
File.writeline ("*PLC TAG HERE*")
Else
End if
Any help is appreciated, thanks!
PS. I don't know much about VBA.
Hi gclshortt,
So out all of the threads you kindly sent me, only one of them is about reading a tag from a PLC
http://www.plctalk.net/qanda/showthread.php?t=70868
ok, and from what I am understanding (correct me if I'm wrong here) what I have to do is the following
'create a tag as tag group
Dim something As TagGroup
If something Is Nothing Then
Set something= Application.CreateTagGroup(Me.AreaName,500)
something.Add "{[PLC_Offline_Tag_file]PLC_Tag}"
Dim VBA_Tag As Tag
Set VBA_Tag = something.Item("{[PLC_Offline_Tag_file]PLC_Tag}")
End Function
If that is alright, that brings a second question,
after the script has run the first time, I am guessing that the value of the tag group won't be nothing, is it something that I have to clear to run the script again? or can I use a different If function for the code?
From what I remember you do not need to clear the group tag to run the script again.
Easiest way is to set it up based on the information you already have and play with it.
That should help you to understand what is going on.
Hello,
I'm getting an error in this line of code when I try to run it
Set VBA_Tag = something.Item({[PLCCC]d})
Saying the following: VBA Code has been halted. Reason: Run-time error - Tag {[PLCCC]d} was not found in the collection
Any advice?
full code is:
Private Sub NumericDisplay1_Change()
Dim File As Object
Then Set something = Application.CreateTagGroup(Me.AreaName, 500)
something.Add {{[PLCCC]d}}
Dim VBA_Tag As Tag
End If
Set File_System = CreateObject(Scripting.FileSystemObject)
Set File = File_System.CreateTextFile(;C:\Users\admin\Desktop\New folder\test.txt, True)
On Error GoTo ErrorHandler
If Not IsError(NumericDisplay1.Value) Then
If NumericDisplay1.Value = 1 Then
File.WriteBlankLines (2)
File.writeline (==========)
File.writeline (VBA_Tag)
End If
End If
Exit Sub
ErrorHandler: LogDiagnosticsMessage Err.Description, ftDiagSeverityError
End Sub
Dear colleagues, I am reaching out for assistance with an issue I am having. I have a code that can successfully insert data from FactoryTalk...
1,058
Hi , in my application i was supposed to read the recipe name in a string & have to display it all other screens of scada & to perform operation...
2,903
Hi, I managed to read all the tags and value from AB control logix but I had problem to read HMI tag and value from FTView SE, can anyone share...
3,200
Hi, I'm working with Factory Talk Studio and VBA coding. So far, I have two questions. If someone could help me I would be really glad. First, I...
17,380
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
173
