FTView SE Unable to Connect to Display Client Manager
Maximuse
Apr 2013
Ontario
51
First time using SE and I'm stumped on this one. I've developed my app, tested it within Studio to a live PLC, I have a valid license. Running V11. What happens is when I try to run the app via the client, the loading screen pops up and starts loading various things but when it gets to the point where it loads the client manager, that pops up for less than a second and then disappears, at which point the green loading bars stop and it stays that way for about 10 seconds, then those disappear and nothing else happens. When I open up the diagnostic viewer I see the error code in the attached picture. I've browsed the internet for a few days looking for possible causes and can't find anything related to this particular issue. I'd love some help on this I'm completely stumped!
https://imgur.com/a/dD9Zckl
2TK6qWc
Hi Ken,
It's a local station. Original development was done on a different laptop, but once I started running into issues I loaded studio onto the client PC and made sure I could open the application there, which I could no problem. Yes, everything is in the standard directories.
2TK6qWc
I am also having the same issue and currently without solution.
Has this been fixed already or does anyone know a workaround.
Also using Ftview Version 11.00 local station.
Application works fine on my own station but doesnt run on the client station
Yes I have set up the local directory using admin and this has gave no problems or errors
I have used the configuration wizard for this
Currently working with IT to check if there is anything blocking my access to the display manager or preventing the manager from running correctly
Hi Ben,
Sorry I missed your post until now. The PC I had issues with was provided by the client. After I spent weeks trying to figure out the problem including getting Rockwell support to look into it, I finally just threatened to wipe the computer and start over without their corporate IT interference. They took it back the next day and magically within 20 minutes it was working. They wouldn't tell me what the problem was or how they fixed it but just disappeared behind the Wizard of Oz curtain and then everything was fine.
Super frustrating. This is a long-winded (I'm still a little upset over the time lost) way of saying I think you're on the right track!
I've got an HMI distributed application for this customer, but we recently changed it (in our office) to a network station because distributed...
8,349
Hi all, My company is building a machine that has a HMI that uses FTview SE Network distributed system. the HMI server and network directory are...
5,768
I have a Pheonix Contact Industrial PC running FactoryTalk View ME Station V6.10.00.9(CPR 9 SR 4). This terminal worked fine at the Machine...
25,027
Hello guys please I want experience with this I am currently working on a scada project using FTView SE and I have an Ethernet IP local area...
32
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
178
