FTView SE V10 Alarming Issues
Jul 2007
Kiruna
600
Hi there,
I've spent over a day now struggling with setting up an alarm and event server for FTView10. Poor documentation tells me they have moved to a localdb install of SQL Express.
I cannot install another instance of SQL express as it keeps giving me an error on SQL Native client 2012.
Is there anyway I can connect to this Localdb in FTView ?
- Create a new database
Definition: FTAE
Computername: xxx\MSSQLLOCALDB
Database Username: WindowsLogin
Database Password: Windows password
Databasename: Alarms_DB
A dialog box "SQL Server Log on" prompts me for a username and password which I key in my Windows Authentication and it fails.
How on earth do I log my alarms?
I don't have a direct answer, but the localdb is intended strictly for FT View to use.
I have in the past installed another instance of SQL Server Express without issue. I think that is the problem you need to troubleshoot.
OG
Yes I accept that but I was hoping to use the localdb just for testing and install another SQL instance when deploying it on site.
Maybe it cant be done?
Hey all, First post! I am trying to embed a web browser into my application to enable us to watch live feed of our AXIS IP Camera. The problem is...
925
This problem has been started since the migration of a v9 application to v10. It's a known issue with Rockwell, and their solutions are not...
943
Hi to every body, i'm newbe to FTV Studio; i need to know (and if is possibile how) change the color of a goto display button object. For...
5,040
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
173
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
224
