FTViewME Trending
Oceansoul
Apr 2010
England
307
I've been asked to add a trend to a PVP HMI. Its only a basic HMI with 5 analogue values that need trending. They are all tank levels scaled 0-100%. I have set up a Data Log Model with my five tags (made sure to start the data log in the start-up page), and have a trend object on a mimic, referencing that data log. Time span (x axis) is set to 10 mins, and range (y axis) is fixed 0-100%.
What i am wanting now is buttons under the trend object to scroll forward or back wards in time (x axis), or "zoom" into the range (y axis). How can i achieve this?
You can use the home/end and left/right keys to move the X axis.
(going from memory because I don't use the trend)
You can use tags for the y min/max. Then change the values of the y min/max tags however you want; ramp up/down buttons, interlocked push buttons, ...?.
Hello members! Long time no post! I hope everyone is doing well and enjoying the new year! Today I have a question about the default program...
1,912
I have an issue Im trying to overcome and I think im just over thinking it. Maybe you all could help. Operation description.... 1) Operator...
3,415
Evening all, Hope you all had a good Christmas and new year. I was looking for some advice, I have looked through the forum and found several...
1,801
Hi all, Two questions reqarding factory talk view machine edition: 1) Button How do you place a button on HMI which write an integer into an...
2,129
I used the FT View ME conversion tool on an existing PanelView standard program I had. The conversion worked and no errors were generated. In a...
5,701
