Ftvs-me display screen securty list
Yes, each screen will have to be opened.
But, you can have FTView Studio do that for you. Use the display XML export.
That will give you 187 plain text files that detail everything in those displays; but in XML format. At the top of each XML file will be the display settings which include the security code.
Code:
<displaySettings displayType="replace" position="useCurrentPosition" [B]securityCode="B"[/B] backColor="#505050" titleBar="false" maximumTagUpdateRate="0.5" focusHighlightColor="lime" disableFocusHighlight="true" size="specifySizeInPixels" width="1920" height="1080" allowMultipleRunningCopies="false" cacheAfterDisplaying="false" sizeToMainWindow="true" showLastAcquiredValue="true" TrackScreenForNavigation="true" TrackName="" allowResizing="false" whenResized="scale" beepOnPress="false" highlightWhenCursorPassesOver="true" interactiveHighlightColor="#EFEFEF" displayOnScreenKeyboard="false" allowButtonActionOnError="false" fieldNotSelectedTextColor="black" fieldNotSelectedFillColor="white" fieldSelectedTextColor="black" fieldSelectedFillColor="white" fieldInErrorNotSelectedTextColor="black" fieldInErrorNotSelectedFillColor="red" fieldInErrorSelectedTextColor="white" fieldInErrorSelectedFillColor="red" startupCommand="" shutdownCommand="" useGradientStyle="false" endColor="teal" gradientStop="50" gradientDirection="gradientDirectionHorizontal" gradientShadingStyle="gradientHorizontalFromRight"/>
At that point, you have some choices on how you want to read the info:
1) open each file in a text editor, like NotePad++
2) use Excel VBA to read all the display settings from each file & put into a spreadsheet
3) use Excel XML import to read all the display settings into a spreadsheet (best choice)
So either you still need to open a file for each or spend a bunch of time learning Excel VBA or XML import.
ASF said:
I would suggest that the information would likely be contained in each individual display file - so you could get into the XML code of each display file, or export and open them with Notepad++ or something, but you're still dealing with 187 separate files.
:whistle:
Hello all, I am stumped about how to validate an expression in order to meeting the following conditions. Here's what I want to do: I have a...
2,831
I would like to change how a alarm display pops up. Right now when there is an alarm it is set to "replace". I dont want the alarm screen to pop...
2,236
I want to add a time stamp to a display in FTVS to show when a tags value was changed. The tag is a switch whose position is a, b, or c. Looking...
2,131
Hello I am having an annoying issue that I cannot seem to figure out a solution to. I am using Factory Talk View Studios 6.10 to create a...
21
10,424
I'm trying to use a Numeric input enable to let users change their HMI password. The only problem is it deletes leading zeros when you enter it. I...
1,945
