"Fun" math problem at Tech Ed
LoganB
Apr 2017
Michigan
607
I'm not at tech ed this year :)mad:) but a coworker shot me this math problem they are asking as part of the experience. Anyone wanna take a crack at it?
just for curiosity sake, any chance you could outline your process? I was just trying to define things randomly and ended up confused.
LOL yeah sure
1. hold ruler to PC screen, measure known distance (10), come up with scaling factor.
2. Hold ruler to PC screen again, measure 3 sides of triangle, apply scaling factor, get side lengths.
3. head on over to http://www.mathopenref.com/heronsformula.html, plug in numbers.
4. post answer with zero explanation and revel in the fact that you're almost clever
If you ain't cheatin' you ain't tryin'
So, using AutoCAD dimensions (more accurate than a ruler against the screen, I would think) and plugging these numbers into the Heron's Formula calculator
FD = 8.9443
DE = 7.0711
EF = 3.1623
It says the area is 10.0002
I can believe that, plus now I have the formula!
Thanks for sharing that!
I also get 10 using AutoCAD.
The way to solve by hand is:
Define a new point X, which is the center (not centroid) of the semicircle, also the midpoint of AD.
Consider a quadrilateral XFCD. Angle XDC is 90, angle XFC is 90, therefore quadrilateral XFCD is symmetrical about the line XC. Angle CXD is atan(10/5), multiply that by 2 to get angle DXF.
From there, the area will be that larger sector (DXF) of the semicircle minus all the little parts, which is straightforward.
I found this code today in a running machine. This routine executes but the bit to call it is only written to inside this same routine... so how...
2,045
Ok simple one let's start counting with pictures thread as a bit of Fun. Rules - Picture must be +1 higher than the previous picture -...
41
11,172
I recently came across a scale slot car drag racing track used for $4500. The racer in me was like cooool. The programmer in me was like, I can...
2,744
I believe I posted something about this last year but here it is again. This Spud Gun has a removable breech that holds the igniter, which is...
2,201
I received my Alexa Echo yesterday and I'm looking forward to automating the home. But I wondered just what other amazing things I can do with...
36
9,839
