Function Block Problem
shantanuc
Nov 2020
Aachen
I am using Codesys as my PLC Programmer. I use structured text as the language.
I tried using a timer inside a function block and then mentioning it in variables of main program but its not getting started. the (IN) of the timer is not getting a TRUE value.
If i write the same code in PLC_PRG then it works.
Do i need to do anything additional to make my timer run? Please Help
Normally you would never reference a timer that is inside of a function block from outside the function block itself. More normal would be to have an input to the function block turn on the timer.
Function blocks are meant to encapsulate a subset of code that you would re-use many times. In this way, you write the code once and then define multiple instances of the code and use it.
Here is a video I made that attempts to help you learn about function blocks and their use:
https://youtu.be/aYwH2O_QOQo
Can you provide more explanation and perhaps screen capture to show us what you mean.
Are using a global tag or are you addressing a tag declared inside the function block? Are you getting any errors or is compiling error free but the time doesn't start?
What I show in the attached screenshot is bad practice but it shows that it is possible, provided the tag is declared as VAR_STAT; a tag declared as VAR will is not accessible from outside the block and if you try you will get compile error.
Hi guys, I have a problem with one shot fp when using it in FB. Fp variable is declared as a stat variable. For some reason it isn't one shot. It...
4,600
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
120
Please see attached file. I need this program in Function Block form but I am totally lost on this. Any help would be appreciated. Thanks!
301
Hi! I am using a TM200CE40T PLC from Schneider to write data over Modbus. I have used Memory words (%MW) before using the Write variable...
537
Hi folks. New to the forum, but been working with PLCs for several years now. Would like some advice on whether you would keep this logic, or...
1,070
