Function Calls in Step7
OK farmboy_jon, you're right. It is correct. And it is one of the most efficient ways to initialize certain variables, since you can influence 32 bits with only 2 lines of code. You mostly see it in OB100 (for S7-300/400), OB101 (for S7-400) and (although restricted to 16 bits) in OB's 20 to 22 for the S5 family.
Kind regards,
Jean Pierre Vandecandelaere
Instructor PLC - SCADA
So I have a program for an Omron CJ1M PLC that I have to reverse engineer for a customer. This PLC is meant to control a water pump station...
1,844
Is this possible? I'll use this scenario as an example. I have a function block that represents the behavior of an I/O card, say a 2 channel...
2,217
I know there is a way to do this...but I'm sufferring from brain-lock at the moment, and can't remember how :) I need to be able to pass a word...
4,903
I am new to programming the Siemens Step 7 Micro/Win software. But I found a useful subroutine albeit Function Call on the internet to provide...
5,849
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
120
