Function DIST-COLL (Omron)
jara
Jul 2010
Cordoba
100
I´m trying to use the function DIST-COLL from Omron, this is my firts time with that function because the PLC don´t support FIFO functions.
I must to do something wrong because don´t work, I have tried to follow the example from user manual
The issues is that the function DIST don´t work, the values D1,D2 always is 0 when I tried to simulate
If someone can tell me what I´m doing wrong
Thank you very much
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
133
Im trying to create a level indicator for water Tank i have used the ADD function while the pump is on and level increasing everything works...
33
1,102
Good morning crew! Ok my logic works but I am missing something. When the start button is pushed it should like the red light for 4sec then shut...
441
Please see attached file. I need this program in Function Block form but I am totally lost on this. Any help would be appreciated. Thanks!
307
The idea here is to provide for a brief rapid influx of message codes while preventing sequentially repeating the same message. i.e. if two...
23
704
