I have lost the cable FX-20P-CABO which goes between the Mitsubishi FXO PLC and the FX-10P-E Hand Held Programmer. Each end of this lead has an 8-pin min. DIN plug. Before I spend a lot of money, can someone tell me if the plugs and cable assembly is a straightforward pin-to-pin arrangement? Also, are all the pins used? Many thanks for your consideration of this.
Regards, Mike
Regards, Mike
