FX PLC RS422 Port
shrirampendse
Dec 2006
Pune, India
157
I have FX 2n PLC having RS422 8pin Minidin port. Ideally we should use Mitsubishi programming cable built in with RS232 RS422 convertor. But I found that If I connect this port with simple RS232 cable , it works. Now, am I going to damage the port by connecting RS422 din port to my computers Com port , directly, without usual convertor?
Mitsubishi Experts pls clarify.
Thanks.
Mitsubishi Programming Cable
Dear CLXenggr,
For Communicating with Mitsubishi FX 2N PLC you need SC09 Cable. Other option is make yourself, if you have expertise (Compentency) in Electronics.
You Quoted : "If I connect this port with simple RS232 cable, it works. Now, am I going to damage the port by connecting RS422 din port to my computers Com port , directly, without usual convertor?"
I don't understand your question?
Repost your question or Mail me.
Bye,
FX plc cable
Thanks for the replies.
I am using the cable shown on this post, only thing I wanted clarification as port electricals differ on Comport and FX RS422 port.
Dear CLXenggr,
Bye,
im trying to connect a fx-1n PLC with hyperterminal using USB-SC09 (rs-232<->rs-422 adaptor). im using computer link with a dedicated protocol...
3,190
MELSEC A RS422 (25pin) <> iQR C24 Serial RS232 (9pin) - Simple PLC Communication Communication from a MELSEC-A Series CPU (RS-422 – DB 25 Pin)...
1,045
Hello All, I have been trolling through the Proface documentation to find an answer, but I read conflicting information. We have a...
3,926
Hi everybody! Im meet a big problem that my PLC is FX1n 24Mr and he has an Rs422 Com port, and the HMI is Delta TP04P series has Rs485 2w...
2,438
Hi I wanted to control 4 Displays to switch input from a PLC with serial interface. The Display can be controlled via its serial port with ASCII...
1,280
