Fx3 cpu
Gattoo
Jul 2014
Durban
Hello Please can someone give me some advise. I am trying to interface a Bar-code Scanner with a Mitsubishi FX3U CPU via the serial port. I have never done this and would appreciate some guidance.
Hi Gattoo
What serial port is it?
Have you installed the FX3U-232-BD (onboard) or FX3U-232ADP (left side)?
I have not try it myself, but I would go and try the "RS" or "RS2" function provided in the PLC
Look in the manual JY997D16601 - "FX3G/FX3U/FX3UC Series Programmable
Controllers - Programming Manual - Basic & Applied Instruction
Edition"
Best regards
/Dariusch
Hi again,
I found this manual where there are example how to communicate with a Printer, bar code scanner etc.
http://www.beijer.dk/web/web_dk_be_dk.nsf/docsbycodename/filearchive?OpenDocument&mylink=/web/BexFilePileAUT.nsf/fm.be.searchframe?Openform&Lang=DK&DocID=FEA066A946FC4C7CC125728E005AB73D
Manual = JY997D16901 "FX Series Programmable Controllers - User's Manual [Data Communication Edition]"
Look at chapter "F. Non-Protocol Communication (RS/RS2 Instruction)"
This will get you startet.
/Dariusch
I'm been deciphering a program for a press here. I've gotten most of it deciphered using the manual to understand the instructions (first mitsu...
388
I’m fairly new to PLC programming. This is our first machine that uses an FX5 PLC rather than an FX3, and therefore GX Works3 instead of GX...
1,275
Hi, can my mitsubishi FX 3 receive wireless I/O signal without PC? By the way, I am using WISE 4210 by advantech, a proprietary LPWAN (Sub-G)...
1,391
I'm trying to communicate between the Mitsubishi FX3 series plc and my Gp2600 HMI through ethernet or serial that is faster than 19200. Mitsubishi...
3,859
I have a 90/30 CPU331. I am trying to upload the program out of the CPU and keep getting an error uploading the logic. Error 8262: Error...
114
