FYI - Rockwell KB article #24984 is NO GOOD
Nov 2013
Michigan
532
Had an issue trying to talk on a DH+ network with RSLinx Enterprise and Classic fighting over my PCMK card. The error message leads to KB article #24984
Step 4 in the solution of this article references article 25029, which is not accessible from outside Rockwell. According to the TechConnect advisor I chatted with, this is because the solution does not work. Of course, this is not indicated anywhere in the article, which caused all manner of headache for me this morning.
So, I'm adding this to the forum so that hopefully in the future if someone searches these error messages they'll find this before going on the Knowledge Base and getting sent on a wild goose chase.
Error messages (for Google's bots):
PKTX: Failed to open device driver handle (null) - Check the JumperID on the PKTX Card.
PKTX failed to connect to CE6PKTX kernel driver using ActivateDeviceEx().
Driver will not start
I know people may not get notices... Dear Rockwell Automation Software User: Rockwell Automation is releasing an update to its notice titled...
7,907
I'm using raspberry pi 4b to poll 3 different plcs with modbus tcp and then publish the tag data using mqtt sparkplug b back to my Ignition...
3,451
This is the second time I ran into this. Really stumped me the first time and I had to flash a process back to V19. Only found this KB article...
2,041
Anyone near Chicago and going? if you go let me know how it is... I would like to go this year sometime but I need to make sure its worth the...
1,879
http://www.ebay.com/itm/281703877644?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649 Mini version studio and rslogix 5000 ver's 13 to 21...
1,880
