G120 VFD restore factory parameters?
flyswatter
Apr 2012
Wrexham
Hi All,
I'm trying to recycle a G120 Siemens VFD in to a new system.
Using a CU240S DP F (safety integrated), I have made a new configuration in Scout but can't seem to download the new configuration to the drive.
I can connect to the PLC system and "go online" over MPI lead from my PC directly in Scout.
I have tried to reset factory parameters to enable the download, but this also comes back with an error.
Both actions come back with a Consistency Check Error.
The drive controller is connected over DP to a CPU314-2DP.
I have not connected a power module, but I should be able to download to the controller with just the 24Vdc supply on to the drive, unless I am mistaken?
Do I need to change a parameter on the keypad to reset something?
Thanks in advance
So I have some Siemens drive that I want to examine the existing setup parameters. From the Operating Instruction manual it shows a "PC...
2,353
Hello all, I am using a Sinamics G120 CP 240E-2 PN-F control unit to drive a Siemens 1LE10030DA222AB4 3-phase 1hp (0.75kW) motor. The motor has a...
5,094
Hey guys, while this question is probably better suited to the Siemens support forums, they've been slow to correct the problem I'm having with...
2,756
Does anyone have a source where I can get some Siemens pre-built diagnostic blocks for G120 P drives? Something akin to FC200? or, are the...
2,425
Hi as a beginner am learning about the G120 (CU240e-2pn) controlled by 1200plc 1-how can i interpret the hex values coming from the vfd...
126
