G3 "complex" programming
joecicpgh
Feb 2013
pittsburgh
19
I dont think it is "complex" but i need a little direction. I want to simply have a "display" pop up when a condition or several conditions are true. In my previous life i programmed in fortran & pascal. I expect it should fall into similar fields.
Thanks,Joe
I just want to do it with a simple display on a page. I have a variable that i only want to alter "if" two conditions are satisfied, a tag is either a "2 or 3" any other value and the display will not be visible.
Thanks,Joe
I know i can write a simple "condition statement" but I am not sure of the structure required. So far what I have tried does not work. Placing the controlling tag in the visible (general) space and (=2) gives me an error.
Joe
Use a data box.
show tab -> display state -> general
Tag1 == 2 || Tag1 == 3
I would set the Data Source value of the data box to Tag1 so you can see the value that makes it visible.
Yes it's very legacy.. but sometimes it's necessary to use old stuff for fun.. and because it's so much cheaper. Crimson 3.0 had the ability to...
1,620
Hello all, I am fairly new to programming HMI's and am working with Crimson 3.1 for the first time. I am trying to recreate an annunciator of...
6,370
What application in your experience has demanded the most complex PLC program? I suppose I should clarify what manner "complex" I'm asking about...
37
12,503
I have this complex code tag that returns as a string variable. For some reason it returns the two strings with a ?? between them -- not the...
3,516
I have my L5K file imported into my project, and the tags I need in the "available addresses". Is there a way to access my PLC tags in a complex...
2,970
